Neutral Light Comes On.
Old 04-12-2022 | 11:08 PM
OLD 96's Avatar
OLD 96
Default Neutral Light Comes On.
In 4th and 5th gear the neutral light comes on. When I shift up to 6th or back down to 3rrd gear it goes out, Bad neutral switch? Or . Some times the key icon (anti-theft) will come on . 2007 Ultra. Any one else experience this? Thanks. Old 96.
Old 04-12-2022 | 11:38 PM
ChromeJunkie's Avatar
ChromeJunkie
I don’t know what the problem is, but check for codes. That may give you your answer.
Old 04-13-2022 | 09:21 AM
Bayou FLHR-M8-128"'s Avatar
Bayou FLHR-M8-128"
I would definitely think neutral switch and very easy change.
There is a deep detent on the shift drum that allows switch plunger to extend and closes the switch. It can't come on unless switch closes when plunger goes down in to the cutout. I would guess the spring on switch is busted and possibly the higher gears gives drum a bit more slack.
Here is the detent. I had to swap the drums when installing a 2014 gearset into a 2017 as neutral swich moved a small bit.
OLD 96 (04-14-2022)
Old 04-13-2022 | 11:51 AM
Warp85's Avatar
Warp85
2nd Gear
Mine has done it once and never again
Old 04-13-2022 | 02:38 PM
PoCoBob's Avatar
PoCoBob
I had a similar problem with my 06 Dyna. I took the switch out, compressed the ball and liberally sprayed around the ball socket with some WD40. That seemed to remove some crud that was stopping it from moving freely. I never had another problem with it.
The following 3 users liked this post by PoCoBob:
btl68 (04-15-2022), Chasingdrakes (04-13-2022), OLD 96 (04-14-2022)
Old 07-12-2022 | 07:51 PM
OLD 96's Avatar
OLD 96
I tried that and it did not work. Wound up having to put a new switch in. Fixed it. Just thought I would give an update in case any one was losing sleep over it.
The following 2 users liked this post by OLD 96:
OkieBill (07-12-2022), s-glide76 (07-12-2022)
Old 07-12-2022 | 08:30 PM
Dirty Dude's Avatar
Dirty Dude
Wasn't losing sleep but I do have a 2007 Ultra so was interested in the result so thanks.
OLD 96 (07-12-2022)
OLD 96
Electrical/Lighting/Alarm
07-04-2019 12:32 AM
kyle90
06-08-2012 06:37 AM
2002EGlide
03-26-2012 07:53 PM
510Sled
08-01-2010 06:16 PM
kwaynea
07-04-2007 07:48 AM
Quick Reply: Neutral Light Comes On.
