M8 Cold start issue
Received 4,918 Likes
M8 Cold start issue
I've got a 2022 Road King with 150 miles so far on the 107 M8. I find it awkward to start when it's cold. (Sitting all night at 30-40 degrees).
When I press the starter button, it fires right up, runs a few seconds then stalls. I have to give it some throttle to keep it running. After about 4 - 5 seconds, I can let go of the throttle and it idles the way it should. After the engine has warmed up, it starts up and runs normally. -- (FWIW.. I'm starting with the transmission in neutral)
Is this normal behavior or should I head down to the dealership to have them do some tweaking?
I'd have the dealer look at it....
When you start it do you take it out and ride it, or shut it down then start it again a few days later, then repeat etc?
