Brake Light Fuse Blowing
Hi all, I have an 06 Street Glide I picked up used. Not perfectly maintained but decent shape. So it blew the brake light/cruise control fuse a few times. I unplugged the rear brake light switch and it has not blown since. I never use the rear brake in normal on road driving anyway so not a risk for safety. I am going to start chasing down the wiring for a short, but I wondered if anyone knew of a place to start based on personal similar experience?
Thanks, JT
Thanks, JT
Longpockets (06-02-2022)
THe brake light works when the rear switch h is connected and you press the rear brake, but the fuse usually blows soon after. I went through the wires in the fairing and checked for a short, no problem found there. So I was wondering if anyone has had a short in the rear brake wiring before that was a known point they had issues with.
If the fuse only blows when the rear brake switch is used it's most likely a shorted or corroded causing high resistance. Replace the switch
Safety is an issue when one of your braking systems is not working. That 20% of total braking force the rear brake provides maybe the difference between short of something or hitting it.
Are you sure it's the Cruise/Brake fuse and not the Accessories fuse?
Isolating the switch seems like he's identified the problem. Then you look at the schematic and realize the Cruise/Brake fuse goes to the Brake relay and not the switch, the Accessories fuse supplies the switch. which then pulls in the relay and the Cruise/Brake fuse powers the Brake light on the fender and tour pak , The C/Brake fuse also goes to the accessories plug 4A, the cruise module, Roll off switch, Cruise enable on the Tac, and the Cruise on/off Dash panel switch before the relay.
JTM65 (07-11-2022)
Thanks all!
Yes I plugged the rear switch in again and rode around a bit. Brake light still okay and no fuse blown. Just got the schematic, thanks for the pic, and saw exactly what you are saying. I need to go through the tail light wiring and see if there is an intermittent short somewhere. Always tricky finding the intermittent problems.
