BOOM AUDIO GTS upgrade no audio
Need some help. Just installed New GTS radio WHIM module and correct harness into my 2015 Road Glide . Install instructions say radio will beep every 3 seconds until programmed by dealer.
I have no audio, Checked unit is not muted and set to speakers. Also swapped over Satellite unit that is not appearing in Menu nor is any Navigation. I waited months for it besides the cost. I am hoping someone tells me its because its not programmed. Popped old unit back in it fired right up and started playing which rules out any issue with amp/wiring.
Thanks for any help
2015 CVO Road glide
2007 Electra glide Ultra
1971 Electra glide
2008 Sportster 1200
Thanks for any help
2015 CVO Road glide
1971 Electra glide
2008 Sportster 1200
The instructions seem to be pretty clear:
Radio configuration using DIGITAL TECHNICIAN II (Part Number:HD-48650) diagnostic tool is:
- Required before audio system OPERATION. System will beep every 3 seconds until configuration is completed.
CVOSLOW (02-22-2022)
As mentioned, you need to get it flashed to work, so install it, get it flashed, and then if there is no audio, you'll be able to properly trouble shoot the issue...
It could be something simple like in the set-up menus, or an issue with the new GTS radio, the WHIM itself, or the harness...
Let us know what happens...
ltcinfantry
Audio Systems
07-21-2020 01:21 PM
