Vibration
Old 08-12-2007 | 06:32 AM
choochoo's Avatar
choochoo
Default RE: Vibration
I assume it could be possible a slighly loose compensator or a stretched, but I would check that last. Personally never felt it with a chain that was loose.
you have to put it on a lift ($60- $150 depending which you buy for home).
remove left running board, and jiffy stand and passenger foot peg.
Drain primary oil.
Remove primary cover.
Then it is best to completely remove the compensator assembly.
Clean the assembly (especially the threads) and reassemble with locktite
and re torque.
I would recommend contacting zanotti hd and get the HD auto chain tensioner while you're at it. possibly best price.
As the chain wears and stretches it gets loose. this would also give the slight (non normal clunk most HD's have) during a shift and roll on the throttle.
Old 08-13-2007 | 10:29 AM
Dalej's Avatar
Dalej
this compensator, what exactly is it? if i take the cover off is it right there, the thing i thought was the clutch. anybody have photos of the compensator removal?
Old 08-13-2007 | 11:19 AM
cudachris's Avatar
cudachris
I have the same vibration with 2007 Roadking it happens at3000 rpm. In any gear.
Old 08-13-2007 | 11:23 AM
Dalej's Avatar
Dalej
I keep the chain adjusted, I did the service work on my fatboy and now the RKclassic, I have never heard of the compensator.
Old 08-13-2007 | 06:43 PM
Dalej's Avatar
Dalej
Well I took off the primary cover and took apart the compensator, cleaned it and put it back together. I did a test ride and no improvement. I think it's got to be in the rear end. the brake disk needs resurfaced and I need a new tire. I will see if that improves the vibes.
Old 08-13-2007 | 07:29 PM
mgmonster's Avatar
mgmonster
Hi guys, I'm no mechanic and new around here, but this vibration problem sounds like worn tire or wheel balance problem. I foolishly didn't check tire pressure, took a ride, hit a railroad crossing too hard, bent a rim, had all kinds of vibration before the tire went flat. Hope I have learned that lesson. The last post stating the need for a new tire was a dead giveaway to me.
Old 08-14-2007 | 05:42 PM
Dalej's Avatar
Dalej
Does anyone know the torque on the compensator?
dwoodlives
07-26-2018 12:48 PM
rider123450
General Topics/Tech Tips
10-10-2011 07:56 AM
SM Radios
10-01-2008 02:42 PM
lou1
05-22-2008 05:41 PM
Ben Sundey
05-02-2008 10:58 PM
Quick Reply: Vibration
