Slip on Fishtails
Old 02-01-2022, 09:24 PM
Richie620's Avatar
Richie620
Richie620 is offline
Default Slip on Fishtails
Looking at getting me some 36" slip on fishtales...but don't want to lose compression in my motor . All the slip ons have that FAT looking fishtale . Was thinking about getting "toqure cones" . Need some advice on what I should do . Thanks
Old 02-02-2022, 07:06 AM
Musician's Avatar
Musician
Musician is offline
Got 36" fishtails on my '08 FLHT. I installed baffles to keep the back pressure from disappearing. Tames the bark, but it's still plenty loud enough for my liking. Also, a LOT easier than installing torque cones. I measured how deep the head pipe is into the muffler, and drilled the mount holes appropriate to that, since they can't be installed from the outlet end. 20 minute job. BTW, mine are NOT the "fat" pipes. 1.75 diameter the entire length. Engine also has the stage 1 intake and feuling reaper torque cams, along with a fuel tuner, so the fuel mix is still good.
The following 2 users liked this post by Musician:
eighteight (02-02-2022), Richie620 (02-02-2022)
Old 02-02-2022, 10:14 AM
Richie620's Avatar
Richie620
Thanks homie much appreciated brotha!!What kind of fishtales are they??
Old 02-02-2022, 10:20 AM
Richie620's Avatar
Richie620
I have a 2014 road king ....could you send me a pic of how them fishtales look like ?
Old 02-02-2022, 11:53 AM
PiedPiper's Avatar
PiedPiper
PiedPiper is offline
Pretty much like this. I did the same thing as Musician.
Richie620 (02-03-2022)
Old 02-02-2022, 11:57 AM
PiedPiper's Avatar
PiedPiper
Big City Thunder is a great place to get the baffles. Just call and tell them how your bike is set up and give 'em a CC card number. They'll do the rest. Having a tuner is probably a necessity if you go this way
Old 02-02-2022, 01:04 PM
Musician's Avatar
Musician
Musician is offline
Cheapies from Dennis Kirk. Don't remember the brand name. Basically straight pipes with the fishtail I think I paid around $170 for them. Good chrome for inexpensive pipes, fit was as good as any other pipes I've ever bought.
Old 02-02-2022, 01:08 PM
Musician's Avatar
Musician
Musician is offline
Only difference I see is that mine has true dual head pipes, rather than the factory headers pipes. Runs cooler, and if I lost a couple pounds of torque, well, I'm not racing it, and where I ride on the tach, I don't notice the loss. The cams and fuel tuner seem to take care of that for me.
Old 02-02-2022, 02:16 PM
PiedPiper's Avatar
PiedPiper
Correct, I did not purchase the the true duals. I went the cheap route first to see if the bike would run well. Once I had it dialed in, I figured leave well enough alone.
Old 02-02-2022, 02:22 PM
PiedPiper's Avatar
PiedPiper
The one thing I do like about my setup is that since I mounted the baffles inside the headers, I can easily change mufflers.
Quick Reply: Slip on Fishtails
