2017 rk dead lithium battery
Wifes RK sat for 2 months while she was riding her 97 Dyna and battery is dead. I understand I need a lithium battery charger and tender for her bike. I see HD has a new 4 battery charger aas well as 2 new single battery chargers.
Anyone have experience with this issue?
According to the description on the charger you posted, it's a "smart" charger. It claims to measure and adjust to match the charging voltage to the current charge status of the battery...
There should be no problem leaving that charger connected to the battery 24/7 when not riding the bike.....
Originally Posted by dodger413
hmmmm, that means the stock alternator / regulator is some special whoop de do that charges lithium batteries ? i doubt it.
I also have the Optimate tender above and use it. It's on the Sporty now since end of October. Like most smart battery tenders, it can stay connected 24/7 and the Optimate will maintain the lithium cells.
OP - did you change out the OEM battery for a lithium on the RK? I don't think they come with that battery, so not sure why it won't hold a charge after a couple months.
How old is that Lithium battery?
This NOCO charger / maintainer looks great.
I don't have one (Yet) as all 3 of my current Battery Tenders work fine but I will keep this in mind if I every buy a Lithium Battery or need another maintainer.
Amazon.com: NOCO GENIUS1, 1-Amp Fully-Automatic Smart Charger, 6V and 12V Battery Charger, Battery Maintainer, Trickle Charger, and Battery Desulfator with Temperature Compensation : Automotive
I'm just curious as to where you got that charging "limitation"....??
hattitude (01-05-2022)
FenderGuy53
08-18-2011 10:35 PM
