voltage drop
Old 08-10-2007 | 12:30 AM
whatzleft's Avatar
whatzleft
Default voltage drop
Tonight while riding my 04 Ultra down the highway I noticed my lights dimmed and the volts on the meter dropped to about 12, then after a few seconds the lights got bright and the volt meter jumped back up to around 15 or so. It did this several times... any ideas on what might be wrong. I'm about afraid to get it out on any rides for fear of something going wrong. thanks for any input.
Old 08-15-2007 | 05:31 PM
Ultrathunder's Avatar
Ultrathunder
Default RE: voltage drop
Mine just did that , it is the regulater, if you keep riding it the stator and rotor will go out
Old 08-15-2007 | 05:38 PM
whatzleft's Avatar
whatzleft
Yeah I actually had another thread on this, I had posted two by accident... I have replaced the regulator and all is well now. Got lots of help from the other thread, Thanks to all.
Old 08-15-2007 | 09:50 PM
HogBack's Avatar
HogBack
IMHO you may want to also check the battery. I have an 04 injected and the long and short is it was the battery....
Old 08-15-2007 | 10:33 PM
StrGlide's Avatar
StrGlide
Be smart about trouble shooting so you don't waste time and money. How would anybody know if "it's your regulator" unless they had the bike in front of them and did the correct tests.
Try checking the battery terminals. If they are loose you would experience the symptoms you mention. Check all electrical connections between the stator, battery and regulator. Bad connections are a likely cause of regulator failure.
Wouldn't you be pissed if you shelled out the money for a new regulator just because a forum member said that was your problem, omly to find out your battery terminals had loosened?
Old 08-15-2007 | 10:38 PM
whatzleft's Avatar
whatzleft
Again, I found the regulator to be bad. This link explains everything involved with this post. https://www.hdforums.com/m_2035815/m...tm.htm#2035815 Again, I accidently posted the org post twice, so this is no longer a problem, thanks for alls concern. The link is actually worth reading concerning this issue.
stmcmann
06-02-2016 12:01 PM
vicsponjr
Electrical/Lighting/Alarm
08-28-2015 09:07 PM
rider718
08-18-2014 08:52 AM
murf1
EVO
05-30-2009 09:25 PM
98UltraEvo
10-05-2008 08:05 PM
Quick Reply: voltage drop
