Low compression on rear cylinder
Old 11-24-2021 | 01:27 PM
alok_pandey's Avatar
alok_pandey
Stage II
Default Low compression on rear cylinder
Hi,
I was on I-5 a couple weeks ago riding to LA on my 2018 CVO limited edition. I was cruising at 75 mostly but I did speed up to 100+ for a few seconds in between. After around 250 miles of ride (I did stop twice for gas), around Bakersfield, my engine started to crank and then gradually my bike shutdown, I pulled the clutch and went on to the shoulder. after waiting for 10 mins I was able to start the bike but the engine light turned on. I slowly took it to the next exit and parked in a gas station. I then found a HD service center which was open in Bakersfield, I was able to ride 30 miles to get there, I rode pretty slow though (55-60). The technician looked at the engine light error code and told me that it's low on coolant, he filled the coolant and also checked the engine oil, surprisingly the engine oil was too low, he filled 3 and 1/2 quarts of engine oil. I had done 10K service on the bike and it was at 13.7K so no reason for engine oil to go so low (there is apparently no leak). I then started to ride towards LA and after 25 miles of ride the bike shutdown again, I was sensing some different engine sound all the time from rear. This time I couldn't start the bike even after waiting 30 mins. I had to tow it to HD service. They have investigated the problem and yesterday I got a call that the problem is due to low compression on rear cylinder. They are tearing down the engine to find out the real reason. The tear down cost itself is ~900 dollars, I am now worried what might be the actual cause and how much more I might end up paying. Any expert advise or comments would be really helpful.
Thanks
Old 11-24-2021 | 01:54 PM
702's Avatar
702
Do some research on "sumping" in the M8 forum here to see if any of the symptoms you noticed matches this issue.
Here's one thread to get you started.
https://www.hdforums.com/forum/milwaukee-eight-m8/1266192-how-do-i-know-if-when-my-bike-is-sumping.html
The following 2 users liked this post by 702:
dasmotorrad (11-25-2021), hattitude (11-24-2021)
Old 11-24-2021 | 05:44 PM
svarnster's Avatar
svarnster
I hope it all works out ok. now is the time for all of those engine mods you have been thinking of, cause that does not sound like a good situation. I would be looking at crank work, big bore, and cams. Making lemonade!
Old 11-24-2021 | 08:31 PM
hattitude's Avatar
hattitude
Thanks
I'm certainly no expert, but even so, it would be hard to say just what happened from just that description......
Based on the engine light being low coolant.... could be it overheated, compromised the rear head gasket, which led to the loss of oil and eventually the loss of compression.. But that's just one of many possibilities...
Based on the engine not running, and no compression, it needs to be taken apart like the dealer is doing, to know/learn anything for sure.....
As mentioned, if you ever entertained the thoughts of doing engine mods to your bike, now may be the time. Whatever they find, they'll need to disassemble for diagnosis, buy parts, and then reassemble for the repair. You'll be paying for the parts & labor anyways... may as well put it back together with "good performance" parts.... Let the depth of the tear down be an opportunity, and decide what engine mods (Stage 2, 3, 4, or performance rebuild) you'll have them do..... But I have to admit, I have the sickness...!
Hope it's something simple relatively simple like just a valve or a head gasket, but keep us posted and good luck with the repair...
Old 11-24-2021 | 09:35 PM
pgreer's Avatar
pgreer
Yep, sounds like oil sumpping. But you can't tell if or how much damage there is without some disassembly. But low compression on the rear cylinder indicates internal damage.
best of luck
Paul
Old 11-26-2021 | 05:09 PM
handirifle's Avatar
handirifle
I would imagine the next thing the dealer checked would be the primary oil level, would be obvious if it was sumping. My guess is rear cyl compression rings seized. Maybe due to overheat from lost coolant?
Just a guess.
Old 11-26-2021 | 05:49 PM
702's Avatar
702
Just a guess.
Transfer and sumping are 2 different issues, and one has nothing to do with the other.
Y2K (11-26-2021)
Old 11-26-2021 | 06:00 PM
handirifle's Avatar
handirifle
Ah I see, misunderstood what sumping was.
Old 11-26-2021 | 06:34 PM
Y2K's Avatar
Y2K
I take it you didn't opt for the extended warranty,how many miles on the bike?
RhynoRocK
EVO
86
09-21-2021 07:53 PM
Junker
Milwaukee Eight (M8)
37
06-19-2019 09:25 PM
danjab
Engine Mechanical Topics
06-11-2017 12:42 PM
lowglide88
EVO
05-06-2009 10:38 AM
swsawyer
Exhaust System Topics
08-01-2006 06:07 PM
Quick Reply: Low compression on rear cylinder
