Tool Advice Please... Torque wrenches...
RE: Tool Advice Please... Torque wrenches...
ORIGINAL: Wags1
You will need at least two. One calibrated in inch-lbs and the other calibrated in ft-lbs. Craftsman makes a 3/8" drive inch-lb torque wrench and a 1/2" drive ft-lb torque wrench. They are fine for "personal" wrenching use.
ORIGINAL: sknyfats
I don't use tools every day (like a full time mechanic)- so the brand or country of origin is of no matter to me. I bought a cheap torque wrench (yes, at Harbor Freight & not the family business)that only specifies foot pounds (doing the math to determine inch pounds is a piece of cake & most manufacturers actually provide a cheat sheet to boot). Two torque wrenches is not needed.
The conversion from ft. lbs. to in. lbs. and vice versa is easy using a factor of 12.
As many mechanics will tell you & others have already said - you can buy top shelf - and guess what? Even they still break without warning - on the first use even. Happens all the time. Go ask your local snap-on & craftsman folks how many returns/exchanges they process on a daily basis.
by law (federal weights and standards) all torque wrenches must meet
the same percentage or error and accuracy.
So you can buy the most expensive or cheapest.
I bought my last three 3/8, 1/2, 3/4" drive at Harbor Freight.
I tested all of them against a buddies snap on set.
Just doing a click test after nut was tight at low, mid, and upper torque of each of the three sizes, they all clicked at same setting.
Not scientific I know but good enough for most applications.
A 3/8" drive will do most everything on your bike.
I have 3 HF torque wrenches that I bought 1 1/2 years ago at HF. One is a 1/4" Drive 20 to 200 inch lb, a 3/8" Drive0 to 80 ft lb and a 1/2" Drive 10 to 150 ft lb and I think I spent a total of no more then $40 for all 3 of them on sale. They seem to work just fine.
