Tour Pak Luggage Rack
RE: Tour Pak Luggage Rack
ORIGINAL: gunrunner
You must position in right place and drill 4 small holes. Screws come up thru bottom to hold on, best I remember they have rubber washers to seal it from water.
Very easily said - a royal Pain in the Butt to get right - I about drove my self crazy before I finally drilled the holes... I was worried that after I got it installed I would stand back and say "well, that's sure NOT straight?"
Maybe its just me.... good luck...
Does NOT leak and I use it all the time out on the road...
piece of cake, just take it slow and follow the directions. place masking tape on the tour pac in the general location of the rack mounting legs. once you get the rack where you want it, draw around the legs with a pencil onto the masking tape. Check it twice when you get done. drill a small starter hole, then enlarge with the correct sized bit for the bolts.
ORIGINAL: gman
