sert
RE: sert
why? you've already paid for it and (assume since you had it installed, you got the CD and dongle) why not use it? Use the $ you're planning on spending for a PC to have it dyno'd and have the SERT map fine tuned for your bike. You certainly can install a PC or other fuel management device, but you already have a fuel management system. I would guess that the PC is designed to operate in conjunction with a stock map, not a SERT map which is loaded in the ECU, and not surea stock map is available other than possibly a HD download.
Are you sure you have a SERT, or did the dealer just do a download?
RE: sert
ORIGINAL: pjbolo
If you had the dealer install a sert, is it possiable after to add a power commander or v/h fuel pack?
thanks, paul
thanks, paul
