Oil plug stuck.
RE: Oil plug stuck.
In my many years I have seen many a drain plug stripped by a crescent wrench. Never found one with
jb weld. I don't think heat is the answer, it could boil the oil and distort the oil pan. I think the only logical solution would be to have it drilled out and tapped to a bigger size.
RE: Oil plug stuck.
I feel so stupid. No spoof here as I've got to get this fixed. My brother in law is going to come over with a portable propain(?) torch. He says heat should brake it loose. I called my dealer and the earliest they can get to it is Friday, which would probably mean I'd have to leave it over the weekend.The tech didn't sound like he knew what I was talking about.I can't be the firsthe has heard of this. What is the worse that it can be?
RE: Oil plug stuck.
Shouldn't JB Weld break faster than it would melt? Maybe hitting it with a large mallet would "break the seal" just enough for you to be able to back it out. BTW, hit your neighbor in the mouth with the Cresent wrench. Cresent wrenches are JUNK!! As for your wheels, bang on those a while too. A hammer is a much more diverse tool than a cresent wrench.
