I recently installed new cobra headpipes and the wide band 02 sensors for my thundermax tuner are to long on the rear pipe and hit the transmission cover. Does anyone know if there is one made shorter ?
The bung as shown in the first pic looks pretty long itself, unless it’s an optical illusion. How proud does that stand? If it is really that long, it makes one wonder how far down in the flow will the sensor actually be able to sit.
Sorry about the bad photo. I have an 2006 FLHTCi with a Thunder Max ECM. I put 2007 stock exhaust pipes on it to use the 02 sensors. Your sensor is not mounted correctly. The bung needs to be moved so the sensor is in the space over the starter.... Trucky911...
