Fender Swap? Roadglide to Ultra Classic?
Old 09-17-2021 | 10:47 AM
rjohnstone414's Avatar
rjohnstone414
Stage I
Default Fender Swap? Roadglide to Ultra Classic?
Hoping someone out there can help... will a front fender from a 2020 Roadglide fit on a 05 Ultra Classic CI?
Old 09-17-2021 | 11:22 AM
byersmtrco's Avatar
byersmtrco
Yep. Should bolt right up. Check tire (fender) width. They put skinny
front tires on Road Glides now.
You will have to do something with the wiring assuming the Ultra
has the fender tip running lamp.
Old 09-17-2021 | 07:56 PM
Ya Tigor's Avatar
Ya Tigor
Rushmore fenders are not plug-n-play to older tourings. You will need to grind a bit to make it fit. There are lot of RG and SG clean fenders for pre-Rushmore bike available.
Old 09-17-2021 | 08:52 PM
lp's Avatar
lp
The shape of the fenders themselves are near the same; however, they mount different and the rushmore fender is slightly lowered.
The rushmore fender has four nuts welded to it's mounting brackets. Bolts pass through the fork lower and engage the fender nuts.
The pre rushmore fenders simply have holes. 4 bolts are used to pass through the fender (from inside the fender) and engage threads located in the fork lowers.
At minimum, you'd have to grind off the nuts...
Mr-DD
07-01-2019 08:42 AM
jory434
Touring Parts
10-18-2013 12:09 PM
Tank Bayard
05-20-2013 07:59 PM
harleyposer
Touring Parts
03-16-2012 11:37 PM
army_sarge
Touring Parts
03-16-2010 08:47 PM
Quick Reply: Fender Swap? Roadglide to Ultra Classic?
