Mueller/Rekluse/AIM Clutch Modification
Old 08-23-2021 | 05:59 AM
jake24lt's Avatar
jake24lt
If you ever decide that you want to install a Rekluse torq drive clutch , stick with their slave cylinder. I originally installed an AIM, (3 times after 2 leaked) I wanted to get rid of the aim SDR and go with the torq drive instead. After I installed the clutch, neutral was nowhere to found. Couldn't get the bike out of gear and would severely creep forward while in gear as well. Spoke to AIM about the cylinder, they were clueless about the Rekluse clutch. Called Rekluse and explained the same. They told me that their slave has a slightly more travel than the AIM. That travel is needed for all the clutch plates to release. Installed the Rekluse slave, and it works perfect.
Old 08-23-2021 | 08:05 PM
ChicagoBikeDriver's Avatar
ChicagoBikeDriver
Originally Posted by UrbanRunner
I currently have a Softbrake reduced-reach clutch lever on my bike.
The owner Rick at Softbrake instructed me, when pairing his reduced reach lever, on a bike with an aftermarket slave cyl, he'd make up a reduced lever that's bent back 3/4" instead of the full 1". With 19K miles on this configuration it's awesome. Apologies for giving you one more angle to consider, please speak with Rick, he can explain it, and most likely exchange your current clutch lever for a reduced reach lever made the way you need it. Good luck!
Old 08-24-2021 | 01:57 PM
ChicagoBikeDriver
On the commute in this morning, the clutch lever contacts the bar when fully engaged, and this is with a 3/4" bent Sofbrake clutch lever, and the Aims LF2. With the regular 1" softbrake clutch lever you're running, and plans for an upgraded slave cyl, you won't get enough lever travel, to fully engage the clutch. We tested mine when install was completed at 71 newtons of force? (I think? and can't remember (Imagine that!))
Old 08-25-2021 | 10:29 AM
stro1965's Avatar
stro1965
Thats interesting. I have the Softbrake lever with a Muller clutch slave on my ‘19, and even with a leather grip wrap I have no issues.
sh4325
2014-2023 Touring Models
14
07-01-2022 12:13 AM
lee123
10-26-2019 08:39 AM
Parts Giant
Vendor For Sale Classifieds
09-24-2019 08:54 AM
Parts Giant
Parts Giant
09-23-2019 11:05 AM
DRBUICK
Milwaukee Eight (M8)
42
12-27-2018 09:33 AM
Quick Reply: Mueller/Rekluse/AIM Clutch Modification
