Check those tire pressures!
For those of you interested... I found this guage and really like it. It is made by EZ-AIR and is very simple to use. It had a clip on air chuck that attaches to the stem quick & easy without a lot of messing around. Its on the end of a flexible hose which I wanted because is so touch to get at the valve stem on the Ultra.
Your compressed air source connects to a valve near the round gauge. Its great because to check the tire pressure you just disconnect the air source from the gauge and leave the clip on air chuck attached! If you need more air you just plug the air source back on and keep inflating. If you put a little too much in... there is a small pressure release button up near the face that you push to release some air until the guage reads your desired pressure.
Anyway, it's a simple guage and makes checking the tire pressure painless. And it comes with a nice little pouch to keep it in. I keep mine with me in the tour pack. I attached a picture of it. Just go to www.getagauge.com and check it out. Best of all... it's only $20!
rwt
11-17-2011 06:04 PM
