New feedback on Progressive 440's
Old 08-06-2007 | 02:02 PM
iclick's Avatar
iclick
Default RE: New feedback on Progressive 440's
ORIGINAL: Streetrunner
iclick, what you said is a little puzzling to me. You weigh 170 lbs which is 30 lbs lighter than me and your shocks are 12 1/2" which according to the manufacturer will be stiffer than the 13"since there is less travel and they want to prevent bottoming out. Yet you say you have the preload set at 3 clicks (very stiff).
Actually, it's three full turns, and since I believe the shocks have 10 or more turns of adjustment in total, three wouldn't seem that stiff. In fact, there wasn't a major difference in ride from the full-soft position.
Mine are totally counterclockwise which is the softest position. The only thingI can figure is that they do soften up with some miles.
You also say that you have bottomed outon occassion but my shocks don't even come close and I have been going over every bump I can find.
It has bottomed out once or twice, but I live in LA and we have the worst roads in the U.S., so I have plenty of opportunities to test this.
There is a number on the spring that denotes how many foot lbs it takes to compress the spring. My spring reads 90/125 (if I remember correctly. I may bewrong and will check again), what rate is listed on yours?
I see no number of any kind on either of these springs, so if it is a tag it must've been removed by the PO, as I certainly didn't. The part number is 440-4001C, which is the standard spring for the FLH bikes, but this same spring is listed as the HD option for Sportsters. What is your shock's part number? Even comparing part numbers would be like comparing apples and oranges for the springs, as the 13" springs are undoubtedly quite different from the 12½.
Old 08-06-2007 | 06:38 PM
sportyrider1's Avatar
sportyrider1
I removed the 13" air shocks from my RK and replaced them with 12" progressive 440's, whole different ride, I weigh around 180# and I run them with no preload. If my wife is on the back then I tale them down 5 turns. The 90/125 is the standard spring
Old 08-06-2007 | 07:07 PM
Streetrunner's Avatar
Streetrunner
[/quote]
The number is actually printed on the spring, it is not a tag. Your printing must have worn off.
Old 08-06-2007 | 07:57 PM
dirtdobber's Avatar
dirtdobber
One minor negative to the 440's is the relatively weak rebound control, although I haven't found this a problem and is just an observation.
This is the reason I tried works performance. I did like my progressive shocks but after getting the works tailor made for my wife and I weight. I still like progressive shocks; I just like the works performance better
Old 08-06-2007 | 09:03 PM
Streetrunner
ORIGINAL: sportyrider1
I re-checked the printing on the spring coils; 90/140, I hope that is standard. When I sit on the seat they are now compressing around 1/2", progressive tech say it should compress about 1". When my 260lb Brother in law sits in the saddle it compresses a little more than an inch.
Here's a question...... do those who have gone from 13" stock to 13" 440's feel like they are sitting a little higher?
faber
03-08-2012 10:04 AM
XARAN
01-05-2012 10:55 AM
snidermire
03-09-2009 06:19 PM
Streetrunner
07-19-2007 10:05 AM
kdietz
06-12-2007 10:11 PM
