Changing air temp to oil temp gauge on 07SG?
RE: Changing air temp to oil temp gauge on 07SG?
Check this out
http://www.wallyscycleworld.com/virt...amp;PVSID=3013
I haven't done the install, but I have read here on the forum that it is not difficult.
Good Luck.
Good Luck.
It's not hard at all. I just did the Wally kit. It comes with the oil temp guage, sending unit and bushing for mounting in the extra tapped plug in oil pan, as well as a pigtail with a deutch connector that uses existing wiring for power. Do a search its been covered fairly well on this forum.
ORIGINAL: Justa5o
Have only had the bike a couple weeks but am finding the air temp gauge about useless. Has anyone changed it over to an oil temp gauge and if so how much did it run ya and how hard to do?
Ijust helped a bud do the job on an 07 ultra. Bought the gauge thru the local dealer at 15% off and the brass adapter at the local napa store ran . We ran the wire down the left side frame tube instead of threading it under the fuel tank. Like someone else said in this post do not buy the filter adapter,$50 something that ya do not need to spend. Also have it installed in my 07 ultra works fine on both bikes. Went to Cape Cod this past weekend and both bikes were the same temp.
