2012 streetglide charging issue
Stage II
I have a 2012 streetglide. I put a new stator, regulator and battery in it last year. When running battery voltage won't go over 12.5 volts and when I rev it up it only goes to about 12.6. Swapped out the regulator and still the same. Did a stator check and it's working properly. Starting to get frustrated as to why it won't go any higher. Also put a test light between the battery negative cable and post amd lit up for a bad ground. Pulled all fuses and when I pulled the battery fuse it would go on and off. Decided to starting disconnecting stuff and unplugged the radio made it go out
Ride safe!
flhtc04
18
04-03-2014 04:28 PM
