Curious to know , at what speed / rpm do you use 6th gear .
I was having a conversation with the tech that did my upgrades and he mentioned that with my setup , I shouldn't be using 6th gear until I hit about 125 km/hr , approx 78 mph . Around here , the speed limit never exceeds 110 kmph , 68 mph , so in reality , I'll never / shouldn't use 6th unless I head down to the us where the speed limit is definitely higher .
I used to be in the habit of using 6th when on long flat straight always , then shift down when passing or riding through twisties .
Since having the cams put in , I've noticed an increase in torque when in 6th doing 110 kmph , no need to shift down .
So , what should I do ? ride the way I do or should I take the advice of the tech and stay in 5th , don't really want to mess up all the upgrades I just completed .
I searched many threads and most are dated , and I'm also thinking there must be a difference in how the engine is / was upgraded .
Thanks in advance for your input !
The following 11 users liked this post by 702:
GOV5 (06-24-2021),
hattitude (06-23-2021),
hvacgaspiping (06-23-2021),
jd05flhtci (06-23-2021),
Keggr (06-23-2021),
and 6 others liked this post.
I like to be in 2500-3000 rpm. I recently noticed that I’m in 6th at around 60 to 65 MPH.
Doing 75 I’m at around 3k rpm my sweet spot. I was just thinking of this, wondering if I go stage II what cam will do the job of 80 MPH at 3k rpm. I don’t ride hard and just like to cruise. But need that low end power and stay in 80’s if I’m doing freeways.
The following 4 users liked this post by pyuchem:
The following 10 users liked this post by Oko:
deadhawg (06-24-2021),
Erilflynn (06-28-2021),
GOV5 (06-24-2021),
Hammz (06-23-2021),
and 5 others liked this post.
Shift into high gear as soon as your engine can pull you without lugging down. Even then it doesn't hurt anything.
Keep your RPMs low when cruising. Downshift when you want more power such as passing.
The following 11 users liked this post by Durango Dave:
Keggr (06-23-2021),
KW HD (06-24-2021),
mucyou (06-25-2021),
When my bike was 96" with wood 555 cams, 6th became more useable and I could shift into it at 65mph. With the stock 96, 6th was useless until 70-75.
With the 107 and depending on the ride, I find myself shifting into 6th as low as 60mph....but I prefer to be in 5th at that speed to have more power on tap at the flick of the wrist.
listen to your bike, not your mechanic. your bike will let you know if your rpms are too low/high. if you're cruising on a long, flat road, being in 6th will keep your rpms lower and your mpg higher. if you come to a climb or need to pass, you can downshift and get it done. as long as i'm over 2k rpm, my bike is happy. if i'm doing a speed that is less than that, i''m downshifting to keep it above that point.
just don't make the mistake that a lot of folks did when hd first came out with the 6 speed. they caught a case of stupid. everyone was fine before, now all of a sudden they want to be in 6th gear at 40 mph, and the bikes definitely don't like that.
The following 5 users liked this post by skratch:
Old Sport (06-25-2021),
pgreer (06-24-2021),
Renegadewolf (06-26-2021),
Uncle Larry (06-23-2021)
