Identify this wheel
Old 06-16-2021 | 11:41 AM
ratpick's Avatar
ratpick
Originally Posted by Rob406
Thank you. Just to be clear, this includes ABS/non abs? Makes no difference?
Originally Posted by caulk04
Correct, the wheels are the same. The bearings are what's different for ABS vs non-ABS.
And from picture it appears you have an ABS bearing in that wheel, though you'll want to confirm. They are a different width than standard bearing, so would need to be changed if wheel is to be installed on non ABS bike.
Old 06-16-2021 | 12:12 PM
PoCoBob's Avatar
PoCoBob
Also the thicker ABS bearing requires a thinner spacer on that side.
The reason the bearing is wider is because the encoder that the sensor reads to determine wheel speed is inside the bearing.
91Eglide!
EVO
21
03-06-2020 08:11 PM
6wolfman9
EVO
09-08-2018 05:49 AM
bludeuce
09-16-2014 10:57 AM
Gliden
11-11-2013 04:49 PM
Quick Reply: Identify this wheel
