Slip-ons keep slipping off....
RE: Slip-ons keep slipping off....
Had the exact same problem after installing SE Slip-ons in December.....I re-used the original clamps, instructions state not too, but dealer said it was fine. Anyway, left pipe kept slipping out. I would tighten and tighten but it would keep slipping out. I bought new HD clamps and installed them....still had same problem. Then I figured it out.....place the clamp near the end of the slip-on like 2kflhrstates. At the end closest to the header pipe you will see a slit....place the clamp there and tighten that baby down real tight. Seems somewhat not logical to place the clamp so close to the end of the pipe, you would think further down the tube would be better, but it is not. near thye end allows the clamp to work I guess. No problems since!!!
All I can say is make sure the V&H clamps are the correct size. I also got the V&H oval slip-ons last year and matched them up to the stock HD ones.
Well, ONE of the V&H clamps was larger, called and V&H sent me a new, correct pair no charge. Went on just fine, no problems.
The torque figure on the slipons is not that high, if you have to crank them down a tremendous amount, they probably don't fit right. The difference between the 2 V&H clamps was very small, but made all the difference in the world in terms of a tight fit. Again, I don't think the torque value was that high in the end. I am too lazy to look, but it's obviously in the HD service manual and probably in the V&H directions.
ace57
'06 FLHRS "mattie"
ace57
'06 FLHRS "mattie"
ORIGINAL: AGR8RID
...place the clamp near the end of the slip-on like 2kflhr states. At the end closest to the header pipe you will see a slit....place the clamp there and tighten that baby down real tight.
