Magic Strobes install causing check engine light to come on
Old 06-04-2021, 06:12 AM
lp's Avatar
lp
lp is offline
Received 2,837 Likes on 1,597 Posts
I didn't read the entire thread, but just in case it wasn't mentioned, the connector you circled is for the Security System Antenna and probably not where you want to connect the strobe.
You prob want to connect it to the light harness which it looks like you've done. Maybe try connecting it back up, and then if you get any codes, clear them and see if they come back.
Getting codes are normal when you disconnect/reconnect cables etc. Usually just clearing them fixes the issue.
How to read and clear codes: https://www.fuelmotousa.com/p-29661-...ble-codes.html
Also, things look different under the seat on the 21's. New ECM etc etc. Things have moved around a bit so that can lead to confusion.
c_l_phillips72 (06-04-2021)
Old 06-04-2021, 06:44 AM
tpcowfish's Avatar
tpcowfish
tpcowfish is offline
I installed an amp, and had to connect it to the battery, after amplifier and speakers were done, and working,I had engine light, went in and cleared all the codes, and all good since, like stated above, maybe a low voltage sensory thing, hope you figure it out
Old 06-04-2021, 09:38 AM
hattitude's Avatar
hattitude
hattitude is offline
Received 8,212 Likes on 4,412 Posts
Call Custom Dynamics...
They have very good customer support. They will handle the issue when you call, or have a tech call you back. The tech will then walk you through both trouble shooting the problem and the fix...
The following 2 users liked this post by hattitude:
c_l_phillips72 (06-04-2021), OkieBill (06-04-2021)
Old 06-04-2021, 11:55 AM
c_l_phillips72's Avatar
c_l_phillips72
c_l_phillips72 is offline
Crazy, today I reinstalled everything just like I did yesterday. Afterwards, I rode to the same gas station and pretended to get gas, then took off again waiting for the check engine light to turn on. I rode all over town and it didn’t turn on once. I’m super happy things are working and the check engine light doesn’t come on.
I was expecting to have to follow instruction on how to clear the codes but never did!
Thanks to all who’ve responded with tips and encouragement.
The following 3 users liked this post by c_l_phillips72:
FunHuman (06-04-2021), lp (06-04-2021), tpcowfish (06-04-2021)
Old 06-04-2021, 12:12 PM
gonemad's Avatar
gonemad
gonemad is online now
Received 7,324 Likes on 2,944 Posts
I had an issue with the CD Magic Strobe after properly installing (I think). I emailed their support contact with very specific info, got a VERY fast reply with a specific remedy to clear the codes and sync my Strobe with my bike’s ECM. The links they sent me also happened to be their published FAQs if I had bothered to look first. DOH. They also followed up afterwards. It’s arguably the fastest and most competent customer service I’ve ever received anywhere.
The following 2 users liked this post by gonemad:
c_l_phillips72 (06-04-2021), hattitude (06-04-2021)
Old 06-04-2021, 07:19 PM
Ragtop's Avatar
Ragtop
Ragtop is offline
Received 1,013 Likes on 577 Posts
You really stopped at the pump and pretended to get gas?? HAHA< now I've heard it all!!
Did you stop on the way home and pretend to eat some food too? :-)
Old 06-04-2021, 09:10 PM
c_l_phillips72
I didn’t actually stop at the pump, but I did park in a parking spot and turned off the bike, just like I did when the issue originally occurred. I didn’t take the gas cap off so I didn’t do literally everything I previously did, but I wanted to replicate it the best I could. Probably was overboard but I felt better after doing it and not having problems.
03nighttrain
2014-2023 Touring Models
08-01-2019 03:02 PM
Tk925
05-17-2018 04:29 PM
jammex
03-01-2014 09:21 PM
Donnylee
03-21-2009 06:00 PM
sumncguy
08-08-2007 11:16 AM
Quick Reply: Magic Strobes install causing check engine light to come on
