Chirping/Squeaking 2013 Road King
Hey Folks,
I have a 2013 RKC that has been making a weird chirping sound here and there for the last 3.5-4 years, INTERMITTENTLY. Doesn't happen all the time, especially when the bike is cold, it never happens then. Wondering if anyone has ever heard this or may know what it is. It seems to have gotten worse recently though (louder and more frequent).
The bike chirps when it gets up to running temperature (225-250 degrees). Some of what I have noticed when this happens:
1. The noise comes on slow and then increases in volume and frequency the more the bike idles and then rides (stop and go type riding). It doesn't ever really do this when going 70-80mph on the freeway but, once its started I have noticed it on the freeway over the sound of my exhaust, and my exhaust is loud.
2. It doesn't do it at all when its cold or at the start of a ride after the bike oil is at garage temps (under 100 degrees).
3. It only does it when the bike is upright. Meaning, when the bike is on the kickstand, it stops.
3.1 When I grab the brake lever, the pitch of the noise gets higher and when I let off, it gets lower. You can hear that in the video at the start til about 16sec in and then I let off the brake until about the 26sec mark when I grab it again and the noise gets higher.
4. Road bumps also make the noise change or affect it's rhythm, as if the frame or suspension is involved.
5. To me it almost sounds like a loose fan belt on a car.
6. There is no loss of performance at any point when the noises start, before or after. Bike runs great.
I have checked everything exhaust-wise as some folks have said they've had similar noises associated with loose exhaust bolts or old muffler grommets. I have tightened the exhaust flanges, hardware and sprayed the muffler grommets with silicone lube, etc. The bike is running Amsoil and is right at the full mark on my dipstick, not low at all.
The only other thing I can think it might be is a problem with the heads themselves. However, as stated above, the bike does not seem to be losing 1 ounce or performance while riding it before or after the noises start.
Bike has the following in it:
-Fuel Moto 107" (was stock 103" until last summer) Bikes been making the noise for a few years
-S&S MR103CAMs - Aug 2020 (had SE 204CAMs since new and made same noise last summer before 107/MR103 CAM upgrade).
-Adjustable pushrods - Since 204 CAMs
-S&S CAM Plate and High Flow Oil Pump - Aug 2020
-S&S Chain tensioner upgrade Aug 2020
Anybody got any ideas?
Thanks!
Thanks!
Received 5,295 Likes
stevec1966 (05-24-2021)
Sounds stupid , but take a short length of hose , maybe 2-3ft long , use it as a stethoscope , you'll know it when you get close .
Definitely sounds like two peaces of metal rubbing together . I would check the kick stand , yes kick stand , there I said it , see if it's rubbing on the frame , missing a bumper or needs some anti seize in the shaft .
Check under the head light , where the brake line branches off and see if the mounting bolt is loose .
Agree , could be the top stabilizer , if you can move it with your fingers , it's time to replace it .
Check your exhaust flanges / bolts , heat shields could be rubbing on the head . I had this issue when I installed my heat shield , sounded the same .
The following 2 users liked this post by Campy Roadie:
OkieBill (05-24-2021),
Final drive belt is not adjusted properly. As the belt heats up it will chirp more. Check rear wheel alignment. Not just belt tension. Motion Pro makes a nice too to properly adjust this. If you get the rear wheel off the ground and spin it, look at the sprocket from behind. The belt should not be rubbing on on the outside or inside of the sprocket.
Received 1,639 Likes
Engaging the brakes means less vibration, so the chirping is lessened. I agree the front engine mounting bracket and/or stabilizer links could be the cause. Maybe the tank bracket boot is worn. Check the bolts to your spot lights or the light bracket.
My 13 King also had a more muted chirping coming from somewhere under the seating area for me a while back. Had the dangest time tracing it. Found out the bottom saddlebag bracket where it attaches to the rear fender was the cause. Tightened it and the noise was gone.
