Brake Master Cylinder Sight Glass Falling Off!
Any suggestion for a quick fix or how do you replace this part? I see there's a part number available online, but how do you install it?
I noticed brake fluid dripping on my bike and found this sight glass came off. Anyone knows what to do?
SIGHT GLASS KIT, MASTER CYLIND 42854-06
Had the same issue... 2011 Road Glide front master cylinder sight glass randomly came out. After reading this post, I opted to do the replacement (part# 42854-06) and it seems to have worked well so far, I'll update if that changes. My local shop had it on hand for $10. I believe that the main problem was that the plastic on the old one became brittle and weak. Plus the o'ring was sloppy. The new one had a nice (very tight) fit. Had to use the back end of a screwdriver and a hammer to tap it in.
lp (10-18-2023)
My sight glass started leaking on my Limited and I bought a replace sight glass from the dealer. The install went well but I never could get the leak to stop. I filed down a dime to fit the hole and used JB Weld to epoxy the dime in the hole. No more leak and I never looked at the sight glass anyway……problem solved.
The following 2 users liked this post by Cobra1:
endorpheus (10-23-2024),
Goose_NC (10-23-2024)
From the Sportster section, maybe this will help.
https://www.hdforums.com/forum/sport...ght-glass.html
FWIW, my M/C has no sight glass, and has not been an issue for 34 years now.
John
John
filthpig
10-08-2015 03:10 PM
whatzleft
02-20-2008 03:26 AM
