Steering head bearing grease
02 Electra Glide Classic
How do you get on the steering head grease fitting. None of my guns won't fit on it, not enough room to get on straight. Looks like I would have to remove part of the fairing or headlight frame.
Am I missing something, this should be easy
The grease fitting is designed to make the owner think he is actually servicing the bearings, but the only thing using that fitting does is pumps a bunch of grease into the steering head and makes a mess.
I will also add that on a bike that old, especially if it is original grease, the bearings really should be removed, cleaned, inspected, and greased by hand.... then reassembled..
When you pump the steering head full of grease through the fitting, it is marginally effective, if at all, at forcing new grease into the bearings.... If the grease in your bearings has gotten old and dried out, in will NOT be displaced by any new grease being pumped into the steering head...
Best to take the time to disassemble the steering head and properly grease the bearings...
Dan89FLSTC (05-14-2021)
