1995 ultra classic headlight problem
Old 05-12-2021 | 07:48 PM
Chad Emert's Avatar
Chad Emert
Stage II
Default 1995 ultra classic headlight problem
1995 ultra classic headlight problem high beam not working trying to change to led lights but high not working on stock or led when plugged in
Old 05-12-2021 | 07:59 PM
im's Avatar
im
Hello and welcome
I believe your bike would use a 3 prong bulb. An H4.
Are you using a 3 prong bulb?
Have you utilized a digital voltage meter or a 12 volt test light in order to confirm that 12 volt power reaches the plug?
Two of the terminals are positive and one is ground.
The high beam function is dependent on the high beam switch.
I will also take a guess that all tests are performed while bike is running.
Note that utilization of an LED bulb will probably not look correct since headlight bucket is not designed for the LED.
Old 05-12-2021 | 08:01 PM
Chad Emert's Avatar
Chad Emert
Stage II
Led headlight comes with mounting bracket for it
Old 05-12-2021 | 08:25 PM
im's Avatar
im
what ?
Dennis O'Connor
08-03-2020 11:43 AM
harleyfiremedic
2014-2023 Touring Models
13
03-03-2020 02:43 PM
bigpappa160
Electrical/Lighting/Alarm
04-27-2018 05:00 PM
falconbrother
EVO
01-27-2015 11:34 AM
wild_one
EVO
26
03-28-2013 02:00 PM
Quick Reply: 1995 ultra classic headlight problem
