EZ BRAKE
Old 08-03-2007, 10:15 AM
finallygotone!'s Avatar
finallygotone!
finallygotone! is offline
Default EZ BRAKE
Has anyone used an EZ brake or Softbrake? They both look like they would be much easier to hit in an emergancy situation, but are a little spendy.
Old 08-03-2007, 10:19 AM
stafford's Avatar
stafford
stafford is offline
Default RE: EZ BRAKE
I put an E-Z brake on and really lilke it a lot. Yes it is pricey. I got my brother something similar at the HD store for about 60 or 70 dollars that is practically the same thing. Feels the same when you ride it as the ezbrake. Can't find the part number tho.
Old 08-03-2007, 10:20 AM
stafford's Avatar
stafford
stafford is offline
you won't get your foot tangled upunder it either. much safer for me
Old 08-03-2007, 10:33 AM
CornbredNE's Avatar
CornbredNE
CornbredNE is offline
I got my Softbrake kit put on at the Johnstown, PA rally a little over a month ago and have close to 2500 miles on since then...I like it with one exception.
In a panic stop (like having a car pull out in front of you when you're passing) the additional leverage on the rear brake can cause you to lock it up too easy.
I love the fit, it lets my 6'3" & 250 lbs stretch out. I like the fact I can't get my foot caught below it like the other guy said. I also did the 1-1/2" longer shift lever and the combination is great, but like everything HD related I dropped about $300 between the shifter, brake pedal and related small parts.
Old 08-03-2007, 11:09 AM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
I found the stock rear brake pedal clumsy, having to lift my foot out from under it to apply the brake, which then felt like I was stomping on it.
The EZ brake allows me to keep my heel of my boot on the floorboard, and apply proper brake pressure very easily. Harley should have redesigned their rear brake pedal decades ago !
Old 08-03-2007, 11:43 AM
nujohn's Avatar
nujohn
nujohn is offline
e-z brake the way to go
Old 08-03-2007, 12:35 PM
HJP's Avatar
HJP
HJP is offline
With EZ brake you do not have raise your foot up to apply the brake. Can not move your feet as far foward on the floor boards compaired to the stock pedal because you boot will not fit under the pedal. If you have factory lowers, the EZ brake will not allow you to open the vents all of the way without the vent holding the pedal down.
Old 08-03-2007, 12:37 PM
0204665J's Avatar
0204665J
0204665J is offline
Just put in on my bike. Very nice, like driving your car. One of my favorite adds. Got mine form M&M with a 15% discount. Worth every cent.
Old 08-03-2007, 12:40 PM
CSI's Avatar
CSI
CSI is offline
I read somewhere that the newer tourers already have the same length pedal as the ez brake....is that correct?
Old 08-03-2007, 12:58 PM
hotpursuit's Avatar
hotpursuit
hotpursuit is offline
the newer ones are longer but they still keep the peddle high.... ez-brake is angled to to extend it out further while keeping it low... MUCH MUCH more rear brake contoll due to heel of foot staying on board...i wouldnt ride a scoot without one from now one...worth every penny... it would be fairly easy to fab one up using your existing peddle, but then youd be paying to have it chromed...
Quick Reply: EZ BRAKE
