Rear axle alignment tool, what is it called?
Old 04-22-2021 | 09:44 AM
trigger1911's Avatar
trigger1911
Default Rear axle alignment tool, what is it called?
I am changing out the rear tire on my 2008 FLHR. Harley makes an axle holder so the axle does not move when I tighten it. what is the part called? I tried many variations and cant find it.
Old 04-22-2021 | 09:49 AM
Jackie Paper's Avatar
Jackie Paper
Snug axle nuts and set the stops on both sides for proper belt tension and tracking. Torque and recheck tension to service manual spec and procedure.
Old 04-22-2021 | 10:06 AM
trigger1911
Tried that many times but one side still turns a bit when tightened.
Old 04-22-2021 | 10:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Third Hand Axle Locker Tool...
slippin_jimmy (04-22-2021)
Old 04-22-2021 | 10:12 AM
Dan89FLSTC's Avatar
Dan89FLSTC
That works fine until you try it with a cam/axle adjuster setup...you must hold the other side with a wrench.
Old 04-22-2021 | 10:21 AM
chief08's Avatar
chief08
just scroll down past quick replay you will find your answer
Old 04-22-2021 | 10:25 AM
scott_0's Avatar
scott_0
Old 04-22-2021 | 10:30 AM
LQQK_OUT's Avatar
LQQK_OUT
I've always been able to use two socket wrenches and just get behind the motorcycle holding the wrench in my left hand on the left side of the motorcycle and using a torque wrench on the right side with my other hand. Maybe a little cumbersome, but certainly not difficult.
GalvTexGuy (04-22-2021)
Old 04-22-2021 | 10:56 AM
Snowfan's Avatar
Snowfan
I call it a stick with screws in it. Works great.
Old 04-22-2021 | 11:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
And exactly how does that stick prevent the other end of the axle from turning when you torque the nut?
The op is not looking for a tool to measure the axle alignment, he is looking for the wrench that holds the other end of the axle when the nut is torqued on an cam type axle adjustment system.
The following 3 users liked this post by Dan89FLSTC:
Campy Roadie (04-22-2021), Snowfan (04-22-2021), trigger1911 (04-22-2021)
Quick Reply: Rear axle alignment tool, what is it called?
