Has anybody has a front wheel drilled and trapped for the Drive pulley
Old 04-19-2021 | 11:46 AM
Mark Fournier's Avatar
Mark Fournier
Stage I
Default Has anybody has a front wheel drilled and trapped for the Drive pulley
I have an 07 ultra that i'm trying to put a 16" by 3" Air Strike rim on it in the rear. The rim is a front rim. The offset will work. but the drive pulley bolt holes are to small. I have a friend that can machine them to the correct size. Has anybody ever done this?
Old 04-19-2021 | 12:18 PM
eighteight's Avatar
eighteight
I have not however assuming the bolt circle is the same there is no reason it can`t be done , plenty of "meat" on that hub
Are there issues with the depth of the bearings "pockets" ?
Mark Fournier (04-20-2021)
Old 04-19-2021 | 12:33 PM
roussfam's Avatar
roussfam
Congrats on your first post and welcome to the Forum
Old 04-19-2021 | 01:04 PM
jkrahn's Avatar
jkrahn
I did this several years ago and have had no issues. I drilled with a hand drill then tapped
Old 04-19-2021 | 09:10 PM
multihdrdr's Avatar
multihdrdr
You can also drill/tap the Rotor side to 3/8" while you're doing the Pulley side.
Your rim/tire will move slightly closer to the belt (that can be a problem for 2003-earlier bikes with a 1-1/2" belt). The hub width and centerlines offset (hub and rim centerlines) are not exactly the same as a rear
eighteight (04-20-2021)
Old 04-20-2021 | 09:59 AM
boasty's Avatar
boasty
I have done this myself no issues for many years. I drilled and tapped myself. Use proper bolts when installing
The following 2 users liked this post by boasty:
DaleM1 (04-23-2021), Mark Fournier (04-20-2021)
Tom Sarno
Wheels/Tires
07-20-2020 10:40 PM
homiegfunk53
General Topics/Tech Tips
08-29-2013 03:57 AM
cwhite6
03-03-2011 05:32 PM
filthpig
10-29-2010 09:20 PM
fogcity123
EVO
24
07-02-2010 04:37 PM
Quick Reply: Has anybody has a front wheel drilled and trapped for the Drive pulley
