Catch can
Old 04-18-2021 | 11:59 AM
MyFavRk's Avatar
MyFavRk
Originally Posted by Ssitruc
Cool.
FWIW, I'd advise against too small a catch can that vents out thru holes around the top... I have used one, a chrome one and paid more than 50 bucks for it. It was like 2" tall total, its volume was soooo small, and would "mist" out of those holes and needed to be emptied a lot. Really noticeably in spring and fall or weather in the 60's and below. It wasn't "horrible" or anything, just would see it on the rear header pipe, cause that catch can hung under the breather.
You bring up a good point , another thread that I had about my catch can build mentioned that . When I have time , I'm going to make a new top for my can without the holes and add another fitting that will run a hose along the bottom of the frame . I thought that I might get some misting on the front of the engine , that and the smell of oil with the way it is .
Old 04-18-2021 | 12:06 PM
kloccwork419's Avatar
kloccwork419
Thats odd that it fills like that. The way they explain it in the video is it needs emptied like every 5k miles or so. Even then it didnt show much was in the can. Maybe it sprayed from all the filter in it or oil level a little high? Ill check into other cans before I pick one out. Great info from everyone so far. I appreciate it
Old 04-18-2021 | 12:09 PM
Ssitruc's Avatar
Ssitruc
I ran the one in my pics above and did not have any misting, so you may be alright. In the top "chamber" I do have a filter medium in it to try and help get anything that didn't "drop out" in the lower chamber, to maybe help it to drip back in the lower chamber. But it didn't mist.... but I did switch to this one. I've made a half dozen or so tinkering with them lol
Before painting fittings black.
Old 04-18-2021 | 12:18 PM
Ssitruc's Avatar
Ssitruc
There's a few different things going on... first, in cool weather, worse if its misty/humid out, and you have a canister that hot air is breathing into... its gonna create moisture. Then you have the air itself with moisture in it. It happens, the hot air from the engine, the outside air, a can that its all going thru... some comes from the engine, some is created by condensation in the can. But once late spring is here and its not "cool" out (60's or below) the issue goes away, and I dump it just when I change the oil. The amount of actual oil is minimal, less than an ounce in the summer, all summer.
The extra length of the catch can helped mine, but in some ways contributed to it in cooler weather.
Old 04-18-2021 | 02:15 PM
SWMB's Avatar
SWMB
On my M8 King I went the easy route and just bought the DK Customs 606 breather assembly with there vent kit and just used there little filter. I've only put about 900 km on this spring and haven't seen any oil drips. Only real difference I've noticed is my fuel mileage has gone up approx 2 MPG.
Old 04-18-2021 | 05:53 PM
kloccwork419
Problem with mine is the mounting plate is too thick for the bolts they supply. I could tap the side like it was suggested above. I might just cut it off completely and buy the kit. Or look at other air breathers with different mounting
Old 04-18-2021 | 06:07 PM
kel03's Avatar
kel03
Some good info on this mod.
kloccwork419 (04-18-2021)
Old 04-18-2021 | 07:11 PM
kloccwork419
If I could find the filter plate that doesnt mount to the breather holes, that would be perfect. Or I modify the arlen ness one I have
Old 04-18-2021 | 08:33 PM
Screamin beagle's Avatar
Screamin beagle
Here's my homemade setup using a cover I made and a water supply line that picked up at lowes. The trick is to get some clear expoxy and put on about a half inch of the hose at each spot before you cut it...keeps the braiding from fraying apart. Then the clamps cover it so you don't even see it. I used a pex t fitting and a crankcase breather from the auto parts store. I have the same setup using black oil/gas hose when I run the stock cover and want a more discreet look. I was able to use the stock bolts and I using the ac/dc intake from fuel moto.
Old 04-18-2021 | 09:12 PM
MyFavRk's Avatar
MyFavRk
You should be able to find a flat backing plate with a separate attachment for the external breather , however , most all backing plates will be bolted on the breather holes to help support the throttle body . I would contact DK , or he might respond to your thread and suggest what might work . You could go with a flat backing plate , with a separate breather attachment, but I think you might have to change out the filter , in that case , in that case , your better off purchasing a new set up and sell the Big Sucker .
Quick Reply: Catch can
