Installing detachable passenger backrest?
Has anyone installed a detachable backrest on a StreetGlide? At the risk of sounding like a complete doofus, I admit that I can't figure it out. The instructions they gave me are for several different things and the diagrams have all the mounts together with no real way to know what is for what. Pics would be excellent.
Thanks,
Barry
Thanks,
Barry
RE: Installing detachable passenger backrest?
Just put one on last weekend. The destructions suck. Searching will net that result. Favorite means I found, drinking a 6pack min of your favorite brew, no kids around for the cussing and swearing, and throwing. What I learned, ignore the stupid instructions, follow the picture to an extent, and tinker. When loosening the two torx head screws in the back, do not remove them at the same time, or itll make things harder when it all shifts on you. I ended up re-installing the rear saddlebag mount in the same location sans a spacer as the pic showed. Everything clears. Do some searching though, someone has pics posted.
ORIGINAL: Justa5o
great, and I was gonna get the setup this weekend and put it on. Maybe I will see how much thedealership charges to install....may be worth the headache this time.
I just did this a week ago and you're absolutely correct. The more I read the instruction the more confused I became so I finally ended up using only the diagram, which helped along with the web site listed below. Even though you have a Street Glide vs. an Ultra I would imagine the hardware kit might be the same type of install. Good luck!
http://linuxworx.org/HD/UltraDetach3.htm
