Changed Bars
Changed Bars
Hello All,
I just equipped the Dominator pre wired 14inch Big daddy 1 1/2 inch apes, on a 2020 Road king specialand the best money I have ever spent. That being said I took the tank of etc to run new lnes (which i did not need after all) and now, like so many threads, will onl kick over and not fire, I am looking for straight answers with people who have fixed this problem as I have not had a ride in a few days and quite eager, that being said I did ubdi the screw before i realised the quick release, done that back up, no leaks or anything but yeah the problem of not firing, now nothing wrong with fuses etc i have tripple checked the seating of the electricals. Please help.
TYI
Sean
TYI
Sean
The new bars look nice! Good work.
Sounds like a fuel delivery issue.
Does the fuel pump prime when you switch the ignition on?
Did you replace the fuel pump fuse if you removed it before removing the tank?
Are you sure the fuel line quick disconnect is fully seated?
Did you double check that the twist grip sensor wiring is connected?
That’s where I’d be starting if I was in your place.
Sean Moody (04-02-2021)
You say you removed the fuel tank...
Did you make sure to reconnect the wiring harness for the fuel pump? It connects to the main bike harness right at the ECM tray, and it connects to the pump assembly under the console if you had that removed (not necessary for tank removal to pull the console).
when i screw it back in it is twisting up, this makes no f'n sense why there would not be a swivel head on this?
Sean Moody (04-03-2021)
