Stuck Oil Filter
Old 03-03-2021, 06:01 PM
br4n0's Avatar
br4n0
br4n0 is offline
4th Gear
Default Stuck Oil Filter
Hey guys,
doing my first oil change on my 05 Electraglide and the oil filter is stuck tight! I’ve tried using a filter socket to no avail. Tried using a band filter wrench with all sorts of paper and tape wrapped around the filter to get more purchase. Nada. I bought one of those nylon strap wrenches, and all it did was crumple the filter. From what I can see online, the next step is taking a screwdriver to the damn thing, but that seems sketchy. Any ideas? Thanks from Noobville.
The following 2 users liked this post by br4n0:
williamfrog (03-03-2021), WVHARLEEMANN (03-03-2021)
Top Answer
03-06-2021, 01:46 PM
br4n0's Avatar
br4n0
br4n0 is offline
4th Gear
Default It’s off!!!
I can’t believe it’s finally over! Thank you to everyone for your tips and encouragement. You didn’t need to spend your helping me, and I really appreciate you all.
A huge shout out to Vipers Harley for his suggestion to drive a tie rod fork into the end of the filter, and using vice grips as a level, twist the damn thing off.
couldn’t have done it without you, Vipers.
I lubricated the new seal with clean oil, tightened it by hand, and then gave it a 1/3 turn with my strap wrench. Pictures included.
Now to top it off with fluids and get back to riding. Cheers, friends!
Old 03-03-2021, 06:06 PM
eighteight's Avatar
eighteight
eighteight is offline
Received 4,988 Likes on 2,862 Posts
Try a strap wrench with rubber before stabbing it please
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,100 Likes on 3,649 Posts
I just did the screwdriver deal this past week
Old 03-03-2021, 06:11 PM
kel03's Avatar
kel03
kel03 is offline
Received 6,055 Likes on 4,358 Posts
Did you warm the bike up first? Screwdriver is always last resort, personally, never had that issue.On install, lube that ring up so it doesn'tn happen again.
Old 03-03-2021, 06:12 PM
702's Avatar
702
702 is offline
Received 5,790 Likes on 2,370 Posts
I have one of these for the stubborn filters.
Amazon Amazon
The following 3 users liked this post by 702:
Fritz Franz (03-08-2021), mjsdouble (03-16-2021), WVHARLEEMANN (03-03-2021)
Old 03-03-2021, 06:14 PM
svarnster's Avatar
svarnster
svarnster is offline
channel locks
The following 2 users liked this post by svarnster:
fossil85 (03-03-2021), WVHARLEEMANN (03-03-2021)
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 30,781 Likes on 11,578 Posts
Make sure the end isn’t dimpled for a wrench.
If it hasbeen on for a long time...the gasket may have welded itself to the seat. Even then I’ve never been unable to break a filter loose with a proper fitting good quality wrench. Not a Harbor Freight one.
Old 03-03-2021, 06:25 PM
br4n0's Avatar
br4n0
br4n0 is offline
4th Gear
i didn’t warm it up. Does that make a huge difference? And how do I reply to you guys without quoting you?
br4n0's Avatar
br4n0
br4n0 is offline
4th Gear
https://www.amazon.com/Motivx-Tools-.../dp/B01BS5B3ZQ
works pretty well, I take it?
Old 03-03-2021, 06:27 PM
702's Avatar
702
702 is offline
Every time.
Quick Reply: Stuck Oil Filter
