Pipes turning color
Old 08-01-2007 | 11:17 AM
Scorpio49's Avatar
Scorpio49
Default Pipes turning color
RG 2007, 700 miles
Right side first pipe (closest to the wheel) at the 45 degree bend is turning color, light tan about 3" above bend and 3" behind bend. Newbie, so I'm trying the best to describe.
Is this normal and what would cause this. I'm coming up on 1000 miles service, what is the dealer going to say about it (yeah I know it's normal) - what should I expect them to do?
Thank you for the help and advice
Old 08-01-2007 | 11:24 AM
Swany RKC's Avatar
Swany RKC
6th Gear
Default RE: Pipes turning color
It's normal, more so on the 07's from being leaned out so much.You can do what I did and install the cover piece from Kuryakan and forget about it.
part #9196 bridge the gap heat shield
Old 08-01-2007 | 11:53 AM
Garemlin's Avatar
Garemlin
It is normal. That is what most of your pipe looks like under the heat shields. Boggles the mind why they leave that piece of the heat shield out. Every touring bike I have seen has the discolored pipe right there unless the filler piece has been installed.
Old 08-01-2007 | 12:08 PM
rome304's Avatar
rome304
bridge the gap.
[IMG]local://upfiles/22213/F9E349BEEC274A4D8EE7C3D79B0AD417.jpg[/IMG]
Old 08-01-2007 | 02:47 PM
Peppa1's Avatar
Peppa1
Get the Kuryakyn piece and you won't be able to see it anymore.
Old 08-01-2007 | 03:52 PM
DelawareDon's Avatar
DelawareDon
Think HD is bad? Try a BMW.....Single-wall pipes with no chrome heat shields! Blue pipes are a way of life for Beemer riders.
Old 08-01-2007 | 03:58 PM
SoCal_Pappy's Avatar
SoCal_Pappy
VERY NORMAL... Get Kuryakyn's Bridge The Gap http://www.kuryakyn.com/products.asp...ey&ci=3317
IBGary
03-10-2012 07:25 PM
fonemann
07-26-2008 03:39 PM
Nevar
Exhaust System Topics
15
01-01-2007 07:24 PM
Corndog
09-26-2006 01:25 AM
Corndog
09-25-2006 11:04 PM
Quick Reply: Pipes turning color
