hogworkz saddle bag liner
Received 1,626 Likes
Originally Posted by Rob175
Their thickness also takes up additional space....and stick on velcro usually doesn't hold up very well in the heat unless it's specifically the "hi-heat" velcro and even then it's problematic.
I use the fitted liners by H-D. Has kept it's shape going on 8 years now and keeps things from rattling inside. Not sure how stretched your bags are, but these are made for the std bags and I have the CVO-style. Just slips off for the luggage liners for trips.
Received 49,745 Likes
I looked at both Hogworkz, and Advanblack before going with Advanblack. First off, the prices are comparable. Advanblack are about $9 more, but a close look at the stitching detail makes up for that. Hogworkz uses a basic single thread diamond pattern, whereas Advanblack uses triple row stitching.
Secondly is the Velcro. The backing of the Advanblack liners act as the loop side of the Velcro, so there's no need stick Velcro tape on the liners themselves unlike the Hogworkz.
The hook side of the Velcro that adheres to the inside of the bags is showing no signs of letting loose after 2 1/2 years as there really isn't a pulling load on it. Should the Velcro let loose in the future, Advanblack supplied enough to completely replace what I've used so far, and then some.
Overall, I'm completely satisfied with the quality and fit. Wouldn't hesitate to purchase again.
Received 74,563 Likes
1fastdude
04-02-2019 08:51 AM
