What Does It Mean When . . .
I can shift into Neutral easy when the engine is cold, but can't after I've ridden 20 miles and the engine has heated up?
I've adjusted the clutch a couple of times, but can't figure out how to compensate for whatever is happening with the temperature change.
Running Redline MTL in the primary and Heavy Shock in the tranny.
RE: What Does It Mean When . . .
That's what I needed to know. Last time I adjusted the clutch I loosened the chain up a little, thinking it was a little too tight -- sure is hard to get a good reading. Must have made the situation worse.
Just a question, what happens if I adjust the chain too tight?
Rickierockit92
13
05-24-2016 08:34 AM
OneBlackFly
09-13-2007 01:48 AM
