oil drops on left front fender of RoadKing
I have an 02 RoadKing and every once in a while, not after everyride, but occassionaly,I notice a very very small streak of oil on the left side of the front fender like it is comming from the lower legsand the wind is blowing it onto the left front fender. It's a very very small amount of oil. Any ideas? Thanks
RE: oil drops on left front fender of RoadKing
Sounds like your one of your fork seals is leaking! Did you have the fork oil replaced at the 20k service? If so, the person who did it may have either put a tear in the seal or damaged the inner strut (while installing the seals). How is your front suspension feeling? Sluggish? Are you bottoming out in front? These are signs that your forks are leaking. Get this looked at ASAP! It can become a safety issue!
ORIGINAL: garcon
Howdifficult is itto replace the frontfork seal? The bike had 15000K service at dealer a while ago, but just had 14400milage.Isit big job. Can anyone who wrenches on their bike do it? Any idea on what a dealer would charge to check and put in new seals? What would be thesafety issue?I don't seem to be bottoming out except when I don't see a deep pot hole and end up going over it, it does sound like it might behitting bottom. Other than that bikerides great.
ORIGINAL: garcon
