oil seepage...
It's going to be tough to figure out with oil covering such a large area. It could be blowing back from many places. I would clean it well with degreaser and ride around the block and check it again. You want to see it when it's just around the area it's coming from. From the pictures it could be the oil filter, base gaskets, stator plug or the primary to block gasket. Or any number of other areas.
bigkahuna479 (01-24-2021)
I agree with everyone above ,but check your oil filter adapter too. They are known to leak too. The top plate and plugs are the locations to look at. And the adapter can be loose at that point. Adapter to engine point where the filter screws on.
