Which Upgrade, Stage 2 or Suspension
Old 01-13-2021 | 12:49 PM
RKZen's Avatar
RKZen
Originally Posted by Bull369
Here are my dilemmas, I broke my back in 06 and broke my neck in 2018 and have had 4 failed back surgeries and a successful neck surgery. The stock suspension isn’t bad to me but it’s not great. If upgrading the suspension would eliminate the painful shock I get if I hit a bump or pothole that would be a big plus. Also, with my wife on the back and the tour pack loaded, I feel that the stock suspension bottoms out hitting said bumps and potholes.
Either invest in the best suspension you can afford or get the doc that fixed Tiger's back. Nice special BTW!
Bull369 (01-13-2021)
  #32
Old 01-13-2021 | 12:58 PM
RJGoose's Avatar
RJGoose
6th Gear
The choice really depends on you and how you ride. Where is the bike letting you down? Does it not handle how you'd like or ride too rough? Go with the suspension. Taking a little too much effort maintaining speed going up an incline while touring two-up? You see where this is going. I'd go suspension, but I ride solo and aggressively and want a bike that handles really well through tight corners and big sweepers. Evaluate where the bike is not performing to expectation and start there.
  #33
Old 01-13-2021 | 01:26 PM
HD Bobber's Avatar
HD Bobber
I would do the suspension, but if you do rear, having the combo with the front will go together hand in hand.
  #34
Old 01-13-2021 | 01:39 PM
400web's Avatar
400web
I would also do the suspension first. on most of my last few bikes and cars I have modified the suspension to suit the purpose that I use them for and the results have been impressive.
Don't just buy off the shelf components and bolt them on, talk to a suspension shop/dealer and ensure that what you buy is dialled to meet your needs.
  #35
Old 01-13-2021 | 01:53 PM
todd-67's Avatar
todd-67
I guess if I insert myself into your position this is the way I would look at it as I have both a stage 2 cam in my 2020 as well as upgraded shocks.
Even using the HD cam you're not going to have that covered by warranty. Those engine mods have to be done by the dealer within 60 days of purchasing the motorcycle to be covered. That being said there are better options than the Harley cam should you choose to go that route. The choice of which would be your personal call based on what you are after. Also consider that upgrading the cam means opening up the intake and possibly the mufflers to take advantage of it along with the tuner. The HD cams you can get away with the tune dowmload from the SE tuner. Aftermarket cam means aftermarket tuner and subsequent dyno tune. You also have the added cost of additional labor vs. adjustable push rods to throw in there. $$ add up pretty quickly.
Now looking at the suspension situation you state that you ride 2 up a lot. The benefit of going to an aftermarket 13" shock is going to make a difference for both you and your wife, more for her than you. Those that don't ride 2 up seem to be the ones stating that the stock suspension is not that bad. I could get my wife to jump on here and give you the testimonial on where she stands on the issue. My buddy blew the motor in his CVO last summer and I loaned him my road king. His fiance called my wife on the first ride that she was on the back of my bike and was raving about the improved comfort over my buddies SG.
  #36
Old 01-13-2021 | 05:30 PM
kojak's Avatar
kojak
yes, my bike came with the hand adjustable shocks. I don’t know if the specials shocks are upgraded from the standard but I’m assuming they are the same.
Adjust them to zero clicks and then ride the bike without bags for a few miles, adjust and ride some more till you find a setting that feels good to you. Try that 1st before you swap them.
  #37
Old 01-13-2021 | 05:48 PM
ChicagoBikeDriver's Avatar
ChicagoBikeDriver
OP, I put my money where my mouth is, and upgraded to Ohlins front, and rear.
I've yet to run across a thread or reply that stated a suspension upgrade on a modern touring bike wasn't well worth the money spent. They more so read like, "Why did I wait so long."
Happy wife, happy life.....
The following 2 users liked this post by ChicagoBikeDriver:
Bull369 (01-13-2021), Old Iron Man (01-17-2021)
  #38
Old 01-13-2021 | 05:49 PM
702's Avatar
702
Half way through the test and you change the question. I want to change my answer to suspension.
  #39
Old 01-13-2021 | 06:05 PM
mlbraptor's Avatar
mlbraptor
I'd rather have a comfortable ride than more power...
The following 3 users liked this post by mlbraptor:
Bull369 (01-13-2021), EdwardK (01-14-2021), victory11 (01-13-2021)
  #40
Old 01-13-2021 | 06:20 PM
internet troll's Avatar
internet troll
Originally Posted by Ironworker69
I changed my shocks and the difference was minimal, a lot of people won’t admit this after dropping $1,000.
That was also my experience. Even after going to a nice rear shock setup, I still get the ever loving sheet beaten out of me. Many of these frost heaves will literally throw you from your saddle. My poor wife has begun to dread certain sections of my most traveled routes. Ive posted about it here before and there were 2 schools of thought. 1) Suck it up whiny boy and 2) throw more money at the suspension.
In the end, I regret replacing the shocks as I feel there was only a 20% ride improvement. But, it is what it is. Ive learned to accept the limitations of my Model (05 EG), the roads around me and my wallet.
Quick Reply: Which Upgrade, Stage 2 or Suspension
