Adjusting Thundermax
Wondering what adjustments you TMAT owners have made. Have an 07 ultra with d & d fatcats (quiet baffle) and ANBS. Put on the above at 600 miles and now have 1000 miles. Before the change, bike pinged at takeoff, esp when hot. I got about 37 mgp. Now bike still pings slightly at takeoff. I have some decel popping. Bike got 33 all hwy miles (rpm cruising range between 2800 and 3000 --65-70 mph.
Base map is 391.
Wondering how I can get a bit better mileage without sacrificing more heat from engine.
Also, will this bike shut down at a certain engine temp? I think I remember reading that the stock ecm had that built in feature. Wondering if the TMAT replicates it.
Base map is 391.
RE: Adjusting Thundermax
I had a pinging problem w/just slipons and big sucker so I kept richening up the fuel from 1024rpm to 2816 on the air/fuel-tpstable. I richened it to the mid 12's. this took care of my pinging but hurt my mpg around town. Then I found a muffler clap a little loose then put my t/max back to the original configuration and have had no more ping and respectable gas mileage. It doesn't hurt to play around w/it you can always put it back if your not happy. Thundermax told me there maps are set up forperformance/economy with room to make adjustments. I am in no way an expert i just make sure i dont lean it out too much so that it will hurt anything.Ifyou do make adjustments youhave to let the auto tune do its job. If you not sure about anything just call thundermax there customer service is second to none.
ORIGINAL: jeffer60
i have an 07 ultra with the tmax my bike did the same thing my cure = go into closed loop settings(under configure)and turn auto tune on, on the module side and on the map side, i also changed the clp settings(the amount the computer can learn) to 15% and35% for both sides, then then click write settings to module, this has worked very good for me, if your not sure about these things call zippers there very helpfull . before you do this be sure to clear all learned fuel adjustments under map editing, good luck . ps check your plugs every so often for discolorization, my mechanic says mine looks good not to grey not to black.
ubreal
18
12-26-2023 07:07 AM
otcauctions
04-25-2008 10:09 PM
