Will this cool the 07?
Old 08-14-2007 | 06:03 PM
JBBOOKS's Avatar
JBBOOKS
Default RE: Will this cool the 07?
14.7:1 A/F ratio is the reason. Thank the EPA.
Harley's current technology won't work properly under EPA guidelines. To meet emissions standards, the EFI is set so lean that excessive heat is the result. To fix it, like Brian said,you need to tweak the fuel and timing, dyno-tune, etc. It's costly and probably illegal. Yes, it really sucks that's what you need to do to make this motorcycle perform like it should. I demo'd some 08s recently and in the 10 mile loop, I could tell how hot they were. I actually felt the heat coming through the seat.
Hopefully, the MOCO will get off it's rear and design a powerful, water cooled V-twin that puts out power, stock off the floor. Then, those who want the classic motor can have it, and those who want power, performance and reasonable temperatures can have that, too.
Personally, I am eventually going to be in the market for an Ultra. I won't move on a new one before the engine problem is resolved. If I need one before that, I'll go with a low mileage 03.
  #52
Old 08-14-2007 | 10:15 PM
Geezer Glide Bob's Avatar
Geezer Glide Bob
ORIGINAL: JBBOOKS
They did design one, It's calleda V-ROD and it does put out plenty of power!
  #53
Old 09-19-2007 | 06:10 PM
Dennis Murawski's Avatar
Dennis Murawski
I have a 2007 FLHT with Screaming Eagle air cleaner, race tuner and slip on exhaust. The dealer installed the most current version of Calibration 78 -- 159PZ004-A1.MT6. I live in Texas and the bike got very hot. A local shop made the following changes to Cal #78:
On the AFR table, removed the closed loop operation by
From 750 to 1250 RPM, setting the value to 13.0 on MAPs 80, 85, 90, 95, 100
From 1500 to 4500 RPM, setting the value to 13.7 on MAPs 80 and 85
On Cal #78, all of these valueswere set at 14.6
On the Closed Loop Bias table, set all values to 798
Any thoughts? Thanks, Dennis
  #54
Old 09-19-2007 | 06:33 PM
oldhippie's Avatar
oldhippie
Rob, get a WallysCycleWorld oil temp guage and I'll help you install it. I installed mine today. Biggestjob is just getting the batwing off. Doing it at oil change time makes sense. You're down there getting dirty at the pan anyways.
ironhorse110ci
11-05-2010 09:42 AM
shekmark
12-20-2008 06:01 PM
SteveO
10-07-2008 01:01 AM
DaveMK
07-14-2008 03:58 PM
lennyhd2002
10-04-2007 08:38 PM
Quick Reply: Will this cool the 07?
