2010 Street Glide OEM 2-into-1 Exhaust
I have an exhaust system from a 2010 Street Glide. This is the factory 2-into-1 headpipe with the Screamin' Eagle Nightstick (80881-10) slip-on muffler which was made by SuperTrapp. Does anyone know if the 4" black muffler tip that covers the final closed or open disc is available as a replacement part? Even if someone has one laying around and wants to let it go, that'd be great too. I've searched high and low and haven't found any results from Harley or SuperTrapp. Any info would be appreciated. Thanks!
I sure you can get the part you need from Supertrapp
If you need a core in excellent shape I could help you.
My advise to you with a Supertrapp exhaust is on a regular basis, remove the 6 allens that hold on the discs and reapply never seize and reinstall.
It is easier if you do it one at a time.
You may be able to find the part at a dirt bike salvage yard
Sorry, I can`t find it either
Can you get a human on the phone at Supertrapp ?
Fwiw the black system I purchased this spring from fuel Moto has the same cap in aluminum finish
pulled out the instructions, no parts numbers
but at least its current so there’s still hope
i still say rotate it 180 and hide the flaw
good luck
good luck
