Detachable Tour Pak Assistance
I just installed the detachable tour pak hardware kit on my '06 Ultra. Needless to say the instructions were not all that helpful so it took awhile to get everything installed and working properly. The next thing I'm going to do is put quick disconnects on the wiring. My plan is to be able to put either the tour pak or a detachable backrest on fairly quickly. By the way, I just found out I need to purchase another hardware kit for the backrest. It never ends! Now that my tour pak is off I'd like to hear how those of you with the same setup install the tour pak without the assistance of another person. Not only is it awkward and heavy to hold but very difficult to see where the brackets align underneath. Any helpful tips would be greatly appreciated. Thanks.
Smitty
Smitty
RE: Detachable Tour Pak Assistance
I hold my tour pack from the rear and squat behind it as I engage the front. I have not installed any connectors. I have an EGC and disconnect the wires inside and pull them out. I connect the antenna and tuck the rest of the harness under the seat. Did you get an antenna relocation kit?
ORIGINAL: Smitty
Smitty
Smitty
At minumumhere are the HD parts you need:
53276-04 - Detachable Two-Up Tour-Pak Rack
53804-06 - Detachable Docking Hardware Kit
If you want to install a detachable backrest you'll also need the following:
53803-06 - Detachable Docking Hardware Kit
52933-97B - Detachable Passenger Sissy Bar Upright (Medium)
There are actually 3 sizes of passenger uprights to choose from (short, medium, tall). Be sure to shop around for the best prices on everything. I find that Zanotti's, Chicago HD and M&M Cycles usually have the best deals. Hope this helps.
Smitty
Smitty
Smitty, I can look up the parts of the antenna relocation kit that you will use.
You will only need a few of the parts and it will cost less the $50.
I can look them up for you but now I am off to Home Depot for a new dishwasher. Let me know if need them.
