stock tour pak mount for '04 EGC
Trying to remove a quick-attach tour-pak mount and replace with stock mounting hardware. Got the quick-attach off okay but can't figure out how to put the stock one back, specifically how to mount the rails that the tour-pak sits on and also where to mount the valve for the airshocks. I thought it just mounted to the front bolt but that interferes with the chrome frame rail cover that fits over it. Anybody got a real close-up picture of a stock set-up?
Thanks,
R0ckie
Thanks,
R0ckie
RE: stock tour pak mount for '04 EGC
Remove your saddlebags and then remove the two chrome strut covers. You can then attach the tour pack rack's front mounting points with bolts. The license plate bracket supports the rear of the rack. Sorry, no pics--the strut covers must come off to install the rack, then go back on after the rack is in place.
