Can anyone tell me what benefits I will gain with these cams, without big bore kit. Will I get more midrange and less low end. What can I expect with these cams. I already understand the benefits of the gear drive cam , just wondering what are the positives and negetives if any? Thanx
They will work better with headwork and a bit more compression than stock.
I had Andrews TW31G's (.510 lift) on my 95" very flat torque curve , pulled great from idle. If you are staying with stock displacement and heads, consider a TW26G.
