Headlamp
RE: Headlamp
Hello Wildwen
Here are a couple of threads that should help you out with a better bulb:
https://www.hdforums.com/m_1950529/mpage_1/key_/tm.htm#1954845
https://www.hdforums.com/m_1960996/tm.htm
As for having to change out your lamp assy. If you just want a better bulb no, get an upgraded H4, say the 65/70 watt Osram, your wiring and charging system will handle that easy. A LOT of people have done this!
Also, I belive you alreadyhave the better charging systemwith your 06. I seem to remember that HD went to a 42 amp (or 40 amp) charging system that year.
Little Arlen
Little Arlen
