1999 and 2000 Road Kings
I recently bought a 2000 Road King with 22,000 miles on it. I was delighted until I found out about the cam bearing failures. The company realized the problem and extended the warranty to 5yrs or 50,000 miles. My bike hasn't failed and it's over 5 yrs old. I feel like I'm riding around with a time bomb and wonder when I will be left stranded on the side of the road. How many of you have actually had a problem? If so, what was the cost? My dealer says the failure rate is about 5%. He says to just ride it and forget it. Thanks, Randy
RE: 1999 and 2000 Road Kings
First of all, it's not just Road Kings, it's all 1999 and 2000 bikes with Twin Cam engines built before Dec. 14 1999. Not the bike build date, the engine build date. I have a 1999 Ultra and have done lots of research. It is a time bomb and no time is a good time for the bearing to fail. If it does it will do other damage and the engine though it can be fixed will not be the pristine unmarked unit you now have. Virtually all of this era of bearing will fail. Fix it now before you have a real big problem on your hands. The cam support plate may need to be changed as well. If nothing else is wrong in there it should run you about 5 or 6 hundred bucks for dependability and peace of mind.
HDF Tech
Engine Mechanical Topics
08-22-2005 11:01 AM
