Rinehart Slip-Ons
RE: Rinehart Slip-Ons
Yes they can be taken out. I have had mine appart & painted the baffles due to rusty water on one end cap after washing. You can take them out & put the end caps back on & run like that. Or you can wrap them with packing to lower the noise level. Of course you probably should readjust your fuel system.
Rini
Rini
Sorry for the hijack.
While on the topic of the Rinehart slip-ons do they perform and sound like the Rinehart TD's??? I know performance won't be exactly the same but do they help?? And with stock headers do they still have the Rinehart sound??? Thinking about maybe getting the slip-ons now and add headers later.
I think they sound great..06 streetglide here with stock headpipes. Tried SE slipons, first set were dented out of the box..did not notice till installed of course, second pair had weld splatter stuck to the outlet end and chromed over. Then tried wild pigs...good fit...ok sound...did not like the look. Then rinehart..sound good..look good...performance little better than stock but i like them as they look like they belong there. Good luck!
ORIGINAL: Monstermile
ORIGINAL: Wags1
They sound great. Not sure what you mean about performance. If you want performance you need to go with a 2 into 1 system. You will pay a performance "penalty", particularly in low end torque, with true duals. The stock headers with the slip ons will perform better than true duals. If you want true duals fine, but do so for appearance, heat, and sound, not for performance.
IMO the Rineharts just plain sound good, no matter what kind of head pipes you are running. You can get the slip ons and run them on your stock pipes but they wont sound quite as good as if they are running on a true dual set up. You cant get Rineharts true dual head pipes later and run the slip ons they are different sizes. You can get another type of true dual head pipe at a latter time or run a conversion on your stock head pipe. Look at www.fullsac.com
selandbe@gmail.com
06-02-2014 11:12 AM
